Hi fellas, I have a 96 limited, I am having a problem with my ldle when the truck is cold, i have to keep my foot on the gas of the engine will die, this happens until the car has warmed up. Then it idles fine.
I Have a CEL, code p0125,
So far i have,
1. Changed the thermostat,
2. Changed the coolant temp sensor,
3. Cleaned and tested the air idle control valve,
4. Tested the 1st oxygen sensor with an ohm meter, = 15 ohms.
What next? Anyone have any ideas?
Thank you.
So far i have,
Thank you.
