Problem with RAS
jetboy1975
I've got a 2004 with the rear air suspension which works great, but for the last couple of months I've noticed the truck is unlevel from left to right (left rear sits 1 inch lower than right). The system seems to work normal, airs up at startup, raises, lowers and holds air, but the difference from side to side continues to be 1" off no matter what the setting.
I'm in the north where they salt the roads so I'm thinking it may just be a dirty or corroded sensor. So here are my questions: what do they look like and where they are located? pics? can they be adjusted? I tried a search without much luck, threads over 4 years ago etc. Some mentioned a pdf file but had no links. Any help appreciated.
I had a similar issue and tried the adjustment and couldn't get it to level out. I think the bags work together, not individually. The sensors work front/rear, not left/right. I think they fill and deflate together, so no way to level side to side. This is all my thoughts after trying to use the sensors to level mine with no success.
I've attached the RAS PDF for adjustment, should help you out. I've got another one on the actual bags themselves, doesn't deal with adjustment but if you'd like it I can e-mail it to you (too large to upload here).
Any updates on this? I have the RAS and just want to keep an eye on this in case I ever run into the same problem.
