TRD04RUNNER said:You have to turn the socket counter clock wise to take it out but its pretty tight up in their unless you have normal size hands hands GL!![]()
It is supposed to turn counterclockwise. TRD04RUNNER is probably right -- it's just tight. Can you get a pair of pliers on it?AlexJet said:I tried, it's still not moving.
bryancos said:See if you can pull up on the tabs holding the headlight in place and pull it forward out of the socket as if you're removing the headlight housing... Its a little more work, but it makes it a little easier to access those sockets... When finished, put the housing back into place and slide the locking tabs back down...
