AddictedOffroad
How much weight does this add? Has anyone pulled out their scales?
Stock vs Awesome
Bumper with crossmember is around 115lbs. So, its only about 65lbs heavier than the stock stuff.
Stock vs Awesome
Stock vs Awesome
Not enough to matter by itself. 90lbs of metal by my guess.
Does this fit with a 1 1/2 body lift?
Is there a no hoop option?
I know you said that the bumpers do not accommodate a body lift. I was just wondering if it would be easy to make a bracket that will raise the bumper from the crossmember similar to other bumper brackets out there.http://www.4crawler.com/4x4/ForSale/Images/BumperBrkts01.jpg
We don't do this. For the simple reason that it raises the leverage on the frame and when winching will bend the brackets and destroy the bumper, body, etc.
Blacking out the area behind the bumper below the fender line will take care of this. If you only have a 1" body lift, then it won't look that bad
I think you are right about that. now I just have to sit tight until black friday.
So, you don't mind a 12-16 week turn time? We typically sell 50 bumpers that weekend.
