Programming '07 SR5 Keyless Remote?
coastal1
I'm trying to program a keyless remote I bought off of ebay. But when I go through the instructions, I can't even get to the programming stage. The locks don't cycle on their own at all, much less the right number of times. Has anyone else run into this problem? FWIW, these are the instructions I was given:
Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
8. TEST REMOTES.
well, i tried just about every set of instructions on the internet and these are the ones i took from another msg board and finally worked
1. Driver's door open, key removed from ignition switch.
Within 5 seconds:
2. Insert and remove the key from the ignition switch twice.
Within 40 seconds:
3.Close and open driver's door twice.
Insert and remove the key from the ignition switch.
Within 40 seconds:
4.Close and open driver's door twice.
5. Insert the key into the ignition switch and close the driver's door.
6. Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitters are currently registered or five times to erase all registered codes.
7.Remove key from ignition switch:
System should now lock and unlock vehicle once, twice or five times
depending which mode has been selected. One to four times, slowly, to
indicate number of remote transmitters registered.
Within 40 seconds:
8.Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
Within 3 seconds:
9.Press LOCK button.
System should now lock and unlock vehicle once to confirm registration,
twice to indicate registration has failed.
Within 40 seconds:
10.Repeat button procedure to program remaining remote transmitters.
SIDE NOTE: To exit programming mode: Open driver's door.
SIDE NOTE: A maximum of 4 remote transmitters can be programmed.
Hope this helps someone.
