Project Werewolf - 1987 4Runner dlx
Night_Wolf84
Starting off I bought this 4Runner back in October 2008. Found it on Craigslist in the St. Louis area. Bought it for $2600 with 114k on the clock, no stereo, no speakers, 3 inch body lift, 33x12.5 Remington Mud Brutes, steel 15 in. wheels, 1 inch helper springs in the rear, factory open 4.10s in the axles, and a low hanging rear hitch.
22RE 4 cylinder, 5 speed manual, original front seats were replaced with used factory blue color seats before I got it, interior pretty good shape other than the cracked dash, and a SR5 gauge cluster out of an '84-'86 model 4Runner was put in (way it was when bought) so I'm uncertain about the true mileage of the truck.
Here it is on the car dolly, bringing her home.
old4runner.jpg~original
Then there she sat at home
874Run8.jpg~original
874Run7.jpg~original
I first installed the expensive $300+ Flex-a-lite electric radiator fan cause the P.O. had a dinky 8in. E-fan in there before.
Long story short...I USED to have an electric fan...recently sold it (2015 sometime) and now have the OEM fan back in there.
Later on I bought Budbuilt's crossmember and skidplate with the 1 inch drivetrain lift. I took it to work and painted it.
budbuilt1.jpg~original
budbuilt2.jpg~original
Old one
crossmember2.jpg~original
crossmember1.jpg~original
New
crossmember4.jpg~original
crossmember3.jpg~original
Before summer of '09 I managed to get myself an Uniden PC78 Elite CB radio and a Wilson 4 ft. atenna with 18 ft. of coax cable. I've looked on TTORA, through the threads of a good spot to put it, but I only liked one spot and that was right next to me in the center console. So, instead of cutting apart the stock console, I tried making one out of wood. That didn't go so well.
Then I tried looking around for one that would fit in between the seats. I looked at several, but they were either too big, or too expensive for my tastes.
Then I remembered seeing that Wal-Mart started selling a center console ment for a van. I took some measurements of the maximum space I wanted it to be in between the seats and read the measurements on the back of the box at Wal-Mart and it came close enough. Best thing about it, if it broke or cracked over time, it was only $30 out of my pocket :usa:
So I took out the seats and everything that'd be in the way. Ran the wiring for the CB under the carpet.
4runnerinterior.jpg~original
Drilled holes where the stock mounting holes were. Cut out slots so the seat belt buckles can move a bit. I painted the grey part the same color as the interior, but I should've done more prep work on it. It only took one movement of the passenger seat to scratch and tear up the paint.
Oh well, someday later I'll make a new one out of steel perhaps. :noidea:
console1.jpg~original
Bolted the CB to the black part of it and screwed it down on the gray part of it. It still needs more scews to secure it properly, but surprisingly it's been pretty solid so far. I guess the seats really keep it snug in there.
console2.jpg~original
Even went as far as cutting out holes for the stock rear window controls
console3.jpg~original
Sometime later and right before the 2009 TTORA Take Over down in Hot Springs, AR. I painted my front grille black and finally got a full size spare tire. I also managed to get my hands on a pretty good used blue tailgate to replace the rusty messed up one that was originally on the 4Runner, put in extended differential breathers for both axles, and put in a LED overhead light.
874Run5.jpg~original
P3300013.jpg~original
P3300012.jpg~original
Sometime after the 2009 TTORA Take Over, I decided to get a bigger and better storage box for all my tools and junk, and also have a better mounting spot for my Hi Lift look alike farm jack.
For the storage box I originally had a $50 Rubbermaid truck box from Wal-Mart. It was ok for a while, but I got tired of digging for my tools and junk out of it. So, I thought about getting a big drawer type of box, but the steel metal type you usually see in expedition type trucks are really expensive for my tastes. I also thought about making one out of wood, but I didn't know how long it would last or how well it would handle the weight of all my junk.
So, I started looking around on the internet for some sort of drawer type of storage box and found a reasonably priced plastic storage box called the "SUV Cargo Caddy". Comes in different sizes and 3 colors. Apparently law enforement uses it, but then again that could be just a advertising type of thing. I believe it was just under $300 when taxes and shipping was added, but don't quote me on that.
Here's the website- http://www.suvcargocaddy.com/index.html
So far it's been working out pretty well. Holds a lot of weight inside and out. I'm over 230 lbs. and I can sit on it without it cracking or anything. It JUST fits in there between the wheel wells and I can still use the factory tie downs in the back to hold on to my spare tire.
It's a little heavy to pull out, but I got all my junk packed in there
P3300004.jpg~original
P3300003.jpg~original
I forget when I installed this next thing, but I would say it was either summer or fall 2009 was when I decided to get an on-board air compressor. I had won a cheap tire repair kit that came with a cruddy air compressor from TTORA Take Over raffle...but it couldn't do what an ARB high output could. So, that's what I bought. The high output (CKMA12) ARB compressor kit.
Here it is installed afterwards...
I know the wiring job looks pretty low rate.
P3300010.jpg~original
Back in winter 2010, Glen of TTORA Arkansas chapter told me the idea of upgrading the brakes on my 4Runner. So I looked into it and found what I needed.
I bought a used dual diaphram brake booster from a '92 V6 4Runner off eBay, bought a new Aisin brake master cylinder ment for a FJ80 Landcruiser off eBay, and bought new calipers, rotors and pads all ment for a '93 V6 4Runner.
Since it was still freezing cold outside and my 4Runner can't fit in the low ceiling of my garage, I had my buddy, who owns his own shop, do all the work.
Then a couple of months after THAT job, I also had him install a Marlin Crawler 1200 ft. lb. clutch kit and replace the clutch master cylinder and slave cylinder...which they needed to be replaced anyway.
P3280001.jpg~original
P3300009.jpg~original
The 4Runner stops pretty good now. As for the clutch, I don't notice any difference compared to the old one, which needed to be replaced cause my flywheel was in bad shape and the clutch disk's springs were loose. In my opinion, all this money spent on just these two upgrades, is well worth it.
Near the beginning of March 2010, I thought it was time to FINALLY get a rear locker and new gears for this rig. My plan is to buy a complete third member from Marlin Crawler.
I'll eventually either get an ARB air locker for the front or a Detroit TrueTrac LSD for it.
As for the rear, I bought a '89 V6 pickup rear axle with the axle shafts for $100, cause my buddy at the shop told me the V6 rear end was stronger. It was only till recently I learned that it wasn't the housing that was stronger, it was the V6 third member that's stronger than the 4 cyl. version. Oh well, I got spare axle shafts if I need them and it'll be easier to work on the axle when I install the new third member.
P4030002.jpg~original
Since I'm going to be spending $1600 on a third member from Marlin Crawler, I figured spending a little more on some armor would be good insurance to protect the new parts for the rear.
I had a co-worker weld it on to the new rear axle for me in exchange for powdercoating some of his parts for him.
P3300001.jpg~original
Around April of 2010, I got a soft top from SoftTopper.com. I install it every other year or so...
P8200016.jpg~original
August 2010 - The new front axle with 4.88 gearing is in the truck and now currently broken in and ready for fun.
Unfortunetly, it remains to be an open axle...it's a long story :/
P8200015.jpg~original
(8-19-10) I finally took the truck in to get its new and improved rear axle, 4.88 gearing and third member with locker installed. However, I'm not letting my buddy hook up the air line, switch, etc. I'd rather do that myself.
The new axle
P8190004.jpg~original
P8200013.jpg~original
I managed to get my hands on a couple SR5 seats. The driver seat I got from Pick'n'Pull for $25. However, someone already snatched the passenger seat. So I emailed my used parts guy in the St. Louis area and he managed to find me a passenger seat that I was looking for.
PA290005.jpg~original
Feb. 19, 2011
Got the new seats to an upholstery shop and got them back this last week.
Went from non-SR5 blue/gray seats to now these reupholstered SR5 seats.
P2190005.jpg~original
Spring...ish 2011. I sold my '04 Tacoma double cab and got a good amount of money out of it. So I started pouring money and time into the 4Runner. Started working on the bodywork to get her repainted and to get rid of the rust/cancer.
I found more rust than I expected.
P9040023.jpg~original
Not only there but up front too. So I got myself a welder and since I couldn't find anyone who sells patch panels at the time, I did my best to make my own patches out of 22 gauge steel (thinner than the factory 16-18 gauge steel) with a hammer, some elbow grease and some dumb luck. :noidea:
It's not the best patchwork, but who cares. No one's going to see it once I cover it back up with bed liner and carpet....right?
I then threw down a fiberglass resin with fiberglass cloth on each patch on the interior part of the truck. THEN I got some green fiberglass putty, that was much like bondo body putty, and put THAT on the outside of each patch.
I had bought used front fenders from a guy a while ago, cause mine were rusting away. Before I threw them on I scuffed, primed, and sprayed rattle-can undercoating on the structure part of the truck to prevent rust.
Just before it got cold that year, I got the 4Runner repainted and now finally the tailgate matches the rest of the truck.
I also threw on Bushwacker fender flares I got for cheap.
I greatly thank my friend, who owns his own repair shop, for letting me spray truck bed liner in his shop. This is POR-15's truck bed liner. Came with a gallon's worth of paint (4 individual quarts), 2 pairs of latex gloves, and an undercoating type of spray gun. I bought an extra quart for good measure and to paint the inside of the fender wells. This is how it came out.
However, I forgot to paint the removable panel that covers the fuel pump. I took it out so I didn't seal it to the floor. Oh well, I'll paint it with rattle-can undercoating later.
Thanks. Yeah it was hard to sell the Tacoma, but because of gas prices at the time, over $3 a gallon, I couldn't afford both the Tacoma's and 4Runner's gas going to and from work.
Thanks, actually it was reasonable for what I got.
I got one with more miles and in way worse condition for $3500
Nice 4Runner. I paid $2400 for mine (148k) in 2010.
That plastic cargo box is slick. It might be just the thing for when the soft top is on. Which size did you get? It looks like it comes with carpet on the top?
Thanks. I like it for now, but later on I'm probably going to sell it and make me a nicer setup so I can have a place to sleep in the back. I forget what size it is, I believe it's the smaller one they sell. It came with the carpet already on it with dividers.
New bumpers
Got new bumpers back in December 2011 (front) and March 2012 (rear) to improve the look and strength of the 4Runner. Bumpers are from Dave'z off road performance. Here's the bumpers before and after. I ended up just painting them with rustoleum gloss black.
After paint and some add-ons, new wheels and tires too :heh:
I welded together a removable angle iron piece to kinda strengthen the spare tire hoist cross-member on the frame, since the rear bumper partially bolts to it.
July 2012--
I took my truck back to my buddy to have a new engine, transmission, and transfer case installed. It damaged my bank account pretty good, but the entire drivetrain is new. Bought the tranny and tcase rebuilt from Marlin Crawler with the 4.7 reduced low gear in the tcase. Also had my buddy install an All Pro driveshaft brake.
Old transmission and tcase
New engine - bored .020 over, Low Range off road 261 "crawler" camshaft, engbldr.com complete remanufactured cyl. head with oversized valves, northwest off road tri-Y header, powdercoated the valve cover myself.
Got the truck back sometime near the end of July. Took the truck back in August cause of a leaking power steering pump and leaking A/C compressor. Decided to let my buddy's mechanics install the Sway-A-Way 25mm torsion bars and Marlin Crawler rock sliders while it's in the shop. Again put a big dent in my bank account for the labor cost, but I have very little left to do before my roadtrip to Moab, Utah in September.
Sept. 2nd, I put the rest of the interior back in the truck and slapped my tire carrier on from CBI off road. During the time I had the truck, before I took it back to my buddy to be fixed, I relocated the license plate to the bumper with a license plate mount I got from a 2nd gen. 4Runner and a '70ish Camaro. It now folds down with the tailgate.
Also I bought a Daystar Cam can with mount to put on the spare tire, made a bracket for a third brake light, relocated the CB antenna to the same bracket, and made easily removable mud flaps.
Sept. 3rd, I started working on the 4Runner around 11am (got a late start) and worked on her till 8:30 last night. Getting the new battery hold down in and wiring up my new 10,000 lb. Warn winch proved to take longer than I thought.
Amsteel blue synthetic winch rope
nice truck! i like that cargo drawer you have, which size did you get that fits perfectly between the wheel wells (there are 3 sizes)? how's it holding up now that you've had it for a while?
It's the mid-size, smallest one they sell. It's been holding up pretty well. It slightly "sunk in" during the summer when I had the spare tire strapped down on top of it, but still holds up with no cracks and holds a lot of weight.
Early April 2013 - replaced the big OEM style headlight lenses and put in new H4 9003 style headlights. Light output slightly went down compared to the OEM style in my opinion. Maybe in the future I'll put in HIDs.
OEM
H4 style
Also decided to ditch the bug shield. I think too much was going on in the front end, so to speak.
I redid the grill and glued/screwed in a mesh screen that was a rain gutter guard originally, then repainted it all satin black.
Near the end of summer 2013, if I remember correctly, I decided to do a visual change on the truck, but didn't really finish with the body work till the following year. Nothin' special, just decided to put on the factory SR5 decals and repaint the hood.
Also to add, I started a small project of getting rid of the Flex-a-lite E-fan and putting on the OEM engine driven fan. However, I didn't really finish it till just a few weeks ago cause I kept getting dragged away from it and also had to modify the fan shroud, cause of the 3in. body lift. Still haven't fully shrouded the entire radiator, but that can wait. Also last month I decided to ditch the OEM sketchy gauges and bought a couple Autometer ones. Didn't finish THAT project till Sept. 4, 2014 cause I had to wait on adapters I ordered or the adapters wouldn't fit, yadda yadda, a big pain in my ass trying to find something that'll work as an adapter. Finally got the gauges in with no leaks.
Thing is though, currently I really need to go back and rewire the lighting for the Autometer gauges and rewire the fog lights, cause when I turn on my rear cargo light, the dash lights for the new gauges go off and also my fog lights turn off. I tapped into the wrong wire that I thought was just the tail lights :noidea:
Feb. 15th 2015- How embarrassing. I was in the drive thru line at the local McDonalds. I shut off my engine so the people inside could hear me over my loud exhaust. Soon as I was done, I tried to start the engine, and the starter finally decided to quit on me. Two guys from inside helped me push it out of the drive thru lane. So I had to call my mom to come pick me up and had to leave the truck in the parking lot. I came back an hour later with my dad. He beat on the starter as I tried to crank it over and it decided to work one more time. I had bought the parts to fix the starter, but haven't gotten around to fixing it.
After taking the starter out and seeing how the drive gear was, I decided to just get a remanufactured one instead.
Feb. 25th 2015 --- What a crappy day. It snowed pretty good and the roads were pretty slick that day. I was driving to work in the Runner and was approaching the exit I take to go to Lee's Summit. There were 3 cars in front of me and the lead car was going 25mph making the other 2 cars almost rear end him. I was approaching a little too fast and couldn't slow down fast enough.
So quickly I decided instead of rear ending the other cars, I went off the road...and ended up hitting and knocking down the exit sign!
It didn't do a whole lot of damage since the bumper absorbed the impact. Busted out the turn signal on the driver's side and pushed the fender slightly so the door scrapped when I opened it. Now the front bumper is crooked/tweaked.
May 2015- I decided to go to the 2015 Lonestar Toyota Jamboree in Gilmer, TX. It was a blast!
Hard to tell, but my dad and I are WAAAAAYYYY in the back
This is how she looks currently. I got rid of the OEM turn signals and moved them inside the side marker lights and converted them to LEDs. I still have to tweak the flasher relay so it'll blink slower, but for now it's alright. As long as people can see it flashing, it doesn't matter too much. I also moved the CB antenna mount to the passenger side and got a red Firestik antenna. The old antenna broke when I took it in to the shop a while ago. A young mechanic raised it up and the antenna got caught and snapped in half. I messed with the mechanic and said "that was a $150 antenna!" Actually it was more like $40, but I didn't care if it broke or not. It wasn't a very good CB antenna anyway.
For the future --
-Make a custom metal center console to replace the worn out $30 Walmart one
-Make a custom cargo drawer/sleeping platform in the rear
-rewire the rear cargo lighting so I can manually turn it on/off while in the back without having the parking lights on
-install a switch to roll up/down the rear window while sleeping in the back
-rewire fog lights & lighting for Autometer gauges
-figure out what I'm going to do with the front and rear bumpers. I used to like them, but now I'm wanting plate style bumpers to have a more OEM look.
Maybe buy new ones or modify the current ones?
The far future or if I get a better paying job --
-Say goodbye to the good ol' 22re I4 and hello to a 5vzfe 3.4L V6 and possibly a matching 5 speed with it. I'd rather keep my W56 HD tranny from Marlin Crawler with matching Tcase. I don't know if I can just change the bell housing so I can bolt it up to the 3.4 or not.
-Fiberglass everything!! Totally want the fibgerglass quarter panels, front fenders, tailgate panel, the L trim pieces for the hard top sliding side windows, and MAYBE one of those Lund style sunvisors they sell at Toyotafiberglass.com
Update
I've decided to put the sway bar back on after taking it off a long time ago. So....I've been driving it without it for a long while, which gets interesting around turns. Now I got quick disconnects for it from 4crawler.com. I'm not too sure how well they'll work, but I'll give them a shot and see. You can also see my A-arm brace in the picture below that I added a long time ago.
Then here's a couple pictures of the small changes I did to the interior and the turn signals in the side marker lights
Tx470
