projector head lamps
hey punk, that's not funny.
I prefer a reflector HID's, and the galactic grey paint scheme doesn't quite do it for me.
However, if the auction remains low, you'll see me in the running.
You're right... It's fahkin hilarious!!!!
I can't view ebay here at work anyway, so I have no idea what that auction is all about. I was just bustin' on ya.
Good luck...
I wish that this post was up 1 month earlier. I started planning my HID retrofit around Xmas and I finally got most of the part I need. Here is what I got:
1 Pair of Black JDM headlight from Jason
1 Pair of Denso ballast and Phillips 4100K bulb from ebay (hidintregra9006)
1 Pair of used 4runner headlight from ebay
1 Pair of Range Rover Shroud
1 Pair of TSX Projector.
1 used solara headlight.
Relay, head shrink butt connector, 12 Gauge wires, fuse, fuse holder, head shrink tub, and etc. for making custom wiring harness
I
ok so here is the break down i contacted partsnet and they replyed with this.
BLAKE PART # 81170 - 35420 $200.00 PART
# 81125 - 35440 $17.50 PART
# 81130 - 35440 $200.00
YOU NEED 5 PEOPLE TOGETHER TO GET THESE PRICES . PLUS SHIPPING COST T H A N K S SAM
let me know whos in and ill talk to them again and see how they want to do this.
im in.
im in.
Please desribe the part's number description more in detail. What about the under headlight piece?:eek:
im in.
81130-35440 - headlight
81170 -35420 - headlight
81125-35440 - i think is the wiring for the turn signals? Not sure exactly.
I know you need h11 sockets though I believe since the 03-05 has a diff socket 9004 or something like that.
talk to the toyota body shop manager today and he said that the o6 front hood grill will fit fine of 03-05 4R and will cover the gap between the lower 06 headlight and trim piece perfectly on the 03-05 bumper!! anyone know the parts # for the fornt hood grill??
Eeeek, this is getting expen$ive. How much does a grill go for now? Those trim pieces can't be less than $50 each.... This has gotta be a $700+ complete HID retrofit from the numbers being tossed around so far....
# 81170 - 35420 $200.00 headlight
# 81125 - 35440 $17.50 Wiring loom for turn signals (use your old ones in conjunction).
# 81130 - 35440 $200.00 headlight
im still waiting for a reply from sam about the metal under garnish not sure the part number.
06 GRILLE ON 2005 4RUNNER
TRIED THE 2006 GRILLE IT TOO BIG ON THE BOTTOM, WILL NOT CLOSE HOOD. AM TRYING TO SEE IF I CAN MODIFY GRILLE OR MODIFY GARNISH. WILL HAVE PART NUMBERS COMING SHORTRLY THE GARNISH UNDER THE HEAD LIGHTS ARE PLASTIC IN 2006.
PROJECTION HEADLIGHT
RIGHT HEADLIGHT- 81130-35470 270.90
LEFT HEADLIGHT - 81170-35450 270.90
FILLER - 52512-35090-B1 33.90
FILLER - 52513-35090-B1 33.90
CORD, HEAD 2- 81125-35440 23.41 EA.
Re: PROJECTION HEADLIGHT
$633.01 BEFORE buying the HID bulbs/ballasts...?! So we're looking at $900+ total?
I'm sure it'll look nice and all, but that's just too much loot for me to spend on some nice looking headlights. I'll toss in the quickie plug and play for under 400.
Re: Re: PROJECTION HEADLIGHT
Finally some prices but yikes!!!!! $633.01
Plus for me the means changing my bulbs(9006) to my Hid kit only.
At this rate of these modifications, we'll better be off buying a new 4runner every year.
Re: HID MOD
mlopez61 said:
I WORK AT A TOYTOA DEALER SO I GET MY PARTS AT MY COST WHICH IS A LOT CHEAPER!!!!!
Does this mean that you can get us some group buy discounts for the guys that are interested here?
Btw, what's this part 81125-35440? I saw it too but wasn't sure what it was for.
Any ideas?
Lastly, how did you convert your plugs to the hid? I'm sure ppl here would be interested in exactly which parts you used for the hid conversion etc etc. Photos will be drooled at i'm sure too :)
Looks great!
So did you use a 9006 harness with an H11 rebased bulb? That's what the guys on the MDX forums are doing when they're converting their headlights from the 9006 reflectors to the H11 projectors.
$600-something dollars not including the HID's is a little steep for me. It'd probably be cheaper just to retrofit and HID projector into the stock 03-05 housing.
Thanks for taking the time to figure it out, it looks incredible.
Re: Re: HID MOD
Any ideas?
To put HID into 2006 headlight, I beleive you need a pair of rebased d2s hid bulb, a pair of ballast and a set of wiring harness like this one: http://www.xenondepot.com/product.php?product_id=50
It allows you to draw power directly from the battery and protect your OEM wiring harness.
For ballast, stick with known brand like hella, phillips or DENSO which is oem for toyota/lexus.
You can also find some information on the difference between halogen & hid projector and some info on how to optimize blub placement in the projector on following page:
http://faqlight.carpassion.info/projector-unit.htm
Hope these will help you guys.:dancin:
