Projector Headlights
karmaic1
Hey All,
I'm looking at getting some Projector headlights for my 06 4runner sport
specifically these
2003-2006 TOYOTA 4RUNNER LED PROJECTOR HEADLIGHTS BLACK - eBay (item 230603403481 end time Jun-28-11 17:25:47 PDT)
i saw a couple people posted threads that had them. Do you have to have a conversion kit with them? If so where is a good place to look for one. I've trolled around ebay but didnt know if someone could suggest a better sight. Also did you install yourself or have it done professionally?
Any feedback is appreciated
Your '06 should already have projector head lights. Are you just looking to change the look a little?...those should fit but you'll have to buy the peice that goes below the head light to make it look right. You might want to search on the forum for the part numbers.
If you do end up getting those head lights, please PM me as I'd be interested in your stock '06 head lights :)
Don't bother with those headlights, unless you really want to have LEDs and halos. From what folks have said about the Tacoma version the quality is questionable. IIRC, it doesn't use 9006 or H11 bulbs and you need to splice in the headlights.
Do a HID Projector Retrofit!!
PM me if you want to see TSX, S2K, LS430 & FX-R HID Projector Retrofit.
they misprinted the years on those, it shouldnt read up to 06, u have projectors already so ditto what uneek said, & besides having to buy the trim for under the lights, those halo's come to a point that may require u to notch the 06 grille to fit em, ive heard the cheap halo rings & led burn out also. if u want/need a brighter bulb, u can do the H9 swap. http://www.toyota-4runner.org/4th-gen-t4rs/59202-08-low-beams-h11-h9.html
thanks for the feedback guys....the more i looked at them i think i will just stick with my factory projector lights and do an HID kit..i'll check out Xenon Depot:wow2::wow2:
