prop/drive shaft greasing
James5354
Hey guys, was wondering how many zerk fittings are on the front and rear drive shafts? and also do you guys use the same type of grease for all the zerk fittings? would like to hear what type and brand of grease you all use as well...
thanks
James
thanks
James
http://www.toyota-4runner.org/4th-gen-t4rs/63518-lubricating-propeller-shafts.html
regular grease in the u-joints & moly grease in the slip yokes, according to the owner's manual. personally, i use Mobil 1 and Valvoline SynPower, respectively.
i was doing some research on the types of grease and found out that some guys are using moly base for the side yokes and lithium base for the u joints.....now I dont really want to be dealing with 2 different guns and have narrowed it down to using amsoil synthetic multipurpose NLGI#2.... and was wondering if any of you guys out there just use 1 type of grease for all the zerk fittings? and what are your experiences.
thanks
James
I have SuperLube in my grease gun for my Icon UCAs. Is this grease suitable for the yokes or u-joints?
*my apologizes for the complete lack of grease knowledge.
thanks
James
I used one grease gun with moly grease for all the zerks on my Land Cruiser. I never noticed anything for better or worse over 5 years.
I bought a second grease gun on sale for $10 for use with the 4Runner with non moly grease, mainly because it was on sale. I wouldn't sweat it either way as long as you're greasing them regularly. When I worked at a dealership everything got hit with the same grease gun with non moly grease.
I checked with my local dealer, and they use Moly for everything. There are many arguments across many different Toyota 4x4 forums on whether you need to use 2 different types of grease on your driveshaft or not. I have yet to find any conclusion, or any proof showing that it does or does not matter.
After hours of searching through conflicting opinions, I gave up, and decided it wasn't worth the time.
Knowing how annoying the "Driveshaft Thump" can be, I just decided to bite the bullet, and get 2 grease guns, and use what Toyota calls for in the Manual. It really isn't that much of an investment. So far, I have been able to keep my 4Runner's driveshaft "Thump Free" for 35k miles.
Every 10k Miles, I use:
Synthetic Polymeric Off-Road Grease, NLGI #2 (NLGI #2 - 5% Moly)
AMSOIL Synthetic Polymeric Off-Road Grease, NLGI #2
For the Slide Yokes
and:
Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2
AMSOIL Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2
For the Spider Gears.
After farting around with a few different cheap grease guns, that always ended up breaking or leaking everywhere, I decided to invest in some decent grease guns, the Lincoln 1134:
Amazon.com: Lincoln Lubrication 1134 Heavy Duty Pistol Grip Grease Gun with Whip Hose and Rigid Pipe: Automotive
You know, it's funny, last time I took mine in for service, they said there really isn't anything to grease under there...
Ended up getting amsoil multi-purpose synthetic grease and pumped it in all the zerk fittings. I just couldn't deal with 2 grease guns. Heard the snap crackle n pop noise from the U joint zerks after 3 pumps and stopped and did about 8 or 9 pumps to the slider yokes and stopped but didn't see any grease drip out on the sleeves of the shaft. Hope I put enough grease in them.
DionicioLives
