jman11788
Member
So I have a horrific groaning noise when I'm coasting under 40. As I turn the wheel the noise exaggerates and when I accelerate at real slow speeds it groans and roars. Also if I turn on the AC it's almost unbearable to listen to at idle
I put my hand on the PS reservoir at idle and its vibrating a lot and I can tell the noise is coming right from it. I did the low tech method in changing fluids to get the old nasty crud out. However after a few days it's getting much worse..
My question is how hard is it for a diy and should I only go OEM pump or will a parts stores pump be fine? Also I've read that if you install a new pump with air in the system it will destroy it. I'm planning to do it this weekend.
