PSA: Maintain your battery terminals
Berty_K
Member
Sharing a maintenance item some may have overlooked (I sure did).
I've spent some time building out my 12v setup. I'll share an observation:
  • With stock terminals, I noticed my alternator charging voltage was fluctuating from 13.3-13.9.
  • With new mil spec terminals (pictured below), my charging voltage holds steady at 13.8-13.9.
My old battery terminals were old and corroded-- I suspect this was causing a poor connection the the battery. I didn't do a full "big 3" upgrade because the Mil Spec terminals gave me flexibility to wire directly to the battery.
You probably don't need to go as far as I did. I assume even a proper cleaning would have made a difference.
y4mzePdVKY7SMaSRwsXokTxKCVJu0amzCqSUduQInEGpMO0xnSY2PMeQ0lB0OxTNCOXTP4eFJ8Jz0bLL45E9fhQBBSnijox5pC_zJlyZVQb03b4hVStiYuofD3D-YNyj2pwFlan5_t-fADiKye_lj1QxfQK0f9rUGEUsTEj-bweuJY
Use a brush to get rid of corrosion.
Then put vaseline on the terminals.
Regarding your setup. Blue Sea is made by Eaton. You can buy the Eaton RTMR and it's 100% waterproof / submersible. Waytekwire sells their switchable circuit breakers real cheap.
The only criticism I can give on your picture is the need for rubber boots over your hot terminals. Don't take the risk of anything arcing when you accidentally lay a wrench in there.
You’re totally right.
These covers off Amazon just came in today. Both terminals are covered now.
Fastronix Military Spec Battery Terminal Covers (Red and Black) Amazon.com: Fastronix Military Spec Battery Terminal Covers (Red and Black): Automotive
H.Sikina
