PTO Winch on 91 Toyota
do you have the pto boxes that would come off the transfer case?
honestly its probably going to be cheaper to buy an electric winch with how much it will cost to have drive shafts made.
No don't have pto box. Have everything else. Need to know where to get my hands on the box. And when I do, where I can mount them.
It's basically a transfer case with 3outputs. And I don't think anyone even makes them for these trucks so it would be all custom. I have one on my 62 jeep truck the pto boxes themselves are a few hundred. You may be able to get a box from kaiserwillys.com but that's the only place I know and then it would have to be custom mounted and Have custom adapters made. As far as I know I've never seen a pto winch on a yota
Trucks and 4Runners have no provisions for a PTO. You will have to make something custom.
There are PTO winches on Toyotas, but they are on the landcruisers. They have the PTO plate on the side of the Tcase, and I have personally worked on Landcruisers with factory PTO winches.
84-85 Trucks/4Runners had a factory Electric winch option, but good luck finding an original one of those.
No shit. Like, I've seen one or two pics, and that's it.
OP, you'll have to do something custom. Maybe build a chain drive to a hydraulic pump off the tcase output, bolt the pump to the side of the tcase crossmember, and run your hose to the winch from there?
wayblom
