pulling after bumper install
t4rFL
Member
i just had an alignment done because my caster was off (less than 200 mi. ago), so it was pulling bad. after i installed my bumper and winch, i noticed the same amount of pulling came back. could the extra weight have knocked it out of alignment already?
How much extra weight did your bumper add to the front end? It could have made the stance squat a bit, throwing off your previously done alignment.
Have you also rotated/checked your tires for any damage done from alignment wear caused before the bumper install?
about 160lbs total, maybe only lost 1/2" in height. tires look good.
How long has it been since the alignment? Most places will give you a guarantee and re-adjust, not sure if they'll hold it though since you did modify the truck afterwards.
If not, most other places will offer free alignment checks to get you in the door.
If you're thinking something happened, get it checked out. The least it'll cost you is some time on your hands to get it diagnosed.
AndiGarage
