Injectors, TPS, ect - you could swap parts out all day and not find the problem. You also could make the problem worse by buying non-Toyota parts and create new problems. If you do swap out the injectors, it seems like re-manufactured OEM is the only legit way to go. :banana:
Misfires can be SO many things. It is not the type of problem I would want to troubleshoot only via forum knowledge.
Injector problems are not that common, based on the forum posts I have seen over last year, they are much LESS common than even a head / head gasket failing, plugs or wires. Injectors are also really expensive.
Do you know what codes it was throwing?
-- Good luck BTW.
First, I should tell you that my E-bay injectors, were Remanufactured OEM's. If you go that route, get them from a local store, not over the internet!
As far as injectors not being a common issue??? Brian.... there were a ton of people over the course of this winter with Injector issues.... myself included. I know of at least 3 other people on here that had the same codes coming up, and the cause was a bad injector.
I'm not saying he should throw parts at it, but simply taking things apart, and swapping one injector with another one from a different location, will cost him nothing, and is a sure fire way to find the culprit. When I did so, it went from a Cylinder 1 misfire to I believe cylinder 5 (which were the 2 injectors I switched around).
I took it to a mechanic friend yesterday. He seemed to think it was the injector. I've got a guy that used to work at a Toyota dealership that I'm going to call today. He helped me with my tons of Camry issues last year. The only code it's pulling up is a cylinder 4 misfire. The tps code is gone. The code scanner belongs to the mechanic I went to yesterday. I used a little pocket scanner and got the same code he's getting. The plugs are new. I'm going to swap wires today. But if it were a wire wouldn't it make more than one cylinder misfire since one wire and coil runs two cylinders? Or is it possible for only one to misfire? Again, bear with me. I'm new at this stuff. I've also heard that injectors rarely go out. But since the truck is new to me, I don't know how well the previous owner took care of it. So I'm trying to look at all possibilities.
If your mechanic friend is willing to help you, ask him to do the swap I suggested.... it's just a little insurance. If you swap in a new one, and it's not that... you've just paid for an injector you didn't need to replace.
Try swapping one of your other injectors for the Cylinder 4 one.... if the code follows to the other cylinder... you're on the right track!
Good luck man! I lost my mind trying to track down this issue with my truck this winter... I just wish I would have listened to someone who told me it was my injector... before I went and bought new plugs, wires, a coil.....
