I know there are many threads on this topic, I just can't find any on these symptoms. My friends 4WD on his 1997 Limited 4Runner with push button 4WD is not working. When the 4WD button is pressed nothing happens. No click and no indicator light no matter if the vehicle is moving or stationary in drive, neutral, or park, absolutely nothing happens when the button is pressed. When the lever is moved into low range it clearly feels like low range is engage but there is still no indicator light. Any ideas would be appreciated. Thanks!!!
To start things off, it feels like it's in low range because manual shifting it actually reduces the gearing, even though it's still in 3WD. (spinning front driveshaft but not enging the ADD which would make it 4WD)
To get the 4WD light to come on, it requires input from the button completing a circuit AND the ADD to be in the 4WD position, if the button makes a noticeable click mechanically, and sinks in a little over 1mm then your button is probabaly fine.
First check the fuse in the fuse block inside of your vehicle conveniently located on the drivers side.
Second, If you have an electrical tester go and check for power from your engine fuse block to your 2WD wire while in 2WD and your 4WD wire when you try to put it in 4LO. If you don't know the difference between the two, just test both wires in both scenarios.
If you don't get power in either scenarios, it could be your relay (located near the glove box) a bad switch on your shifter, or maybe even a bad fuse in the engine block (I can't remember which one it draws off) If it's this problem then I'll go look into mine again to give you exact details or you can look up another post.
If you do get power in either scenarios, there is a decent chance it's bad vacuum lines to the ADD actuator. If you go under the rig in the front and have your buddy switch it back and forth, you should hear clicking if that's the case. If not, you may have a fried ADD actuator... But that's super rare from what I've heard.
Extra testing would be to put it in 4LO, run a hot wire to touch on and off to the 4WD wire of the actuator, and listen for the actuator clicking back and forth. This can also potentially turn your 4WD light on so have you and your buddy working together to check this one.
I've probably missed a couple points as I am exhausted, (please fill in anything I missed guys) but hopefully this helps and puts you on the right track.
Sent from my FRD-L04 using Tapatalk
