Put in fresh carpet, painted wheels, tail lights..
4runnin83
I yanked out the old carpet, it was ****ty from the last owner not taking care of it. I also found 3 joints, and a knife lol.
A good thing I found was that 2nd gens have a drain, so I guess if you were to rhino line the whole interior you could just hose it like jeeps.
IMG_1585.jpg~original
IMG_1583.jpg~original
IMG_1584.jpg~original
IMG_1587.jpg~original
IMG_1588.jpg~original
IMG_1611.jpg~original
IMG_1612.jpg~original
What carpet kit did you use? Did you like the overall fit or did you have to trim a lot off?
SV, I picked up 2 rolls at Autozone, 10 bucks a roll. Its made from recycled bottles and tires. I only had to cut the edges and tuck them under the center console. The hardest part is cutting the holes out for the seat belt and seat bolts lol.
You'll want to use that adhesive glue in an orange can w/ a blue cap. Forget whats it called, but its good stuff.
You use one roll on the pass side, one roll on driver side, roll it longway towards the rear seats (which are removed) and cut and trim, meeting in the middle under the console
If you want to do the 'bed' part, you'll need a 3rd roll. Mine is rhinolined so I didnt bother.
Looking For Carpet Padding
Tnx for sharing. I peeled mine out and washed in front-loading machine. Clean and smells fresh now :)
Did you replace carpet padding? I'd like to replace mine with something that would help dampen noise and further insulate from heat coming up from drive train hump. (Already P&S'd the floor and body panels). Now just looking for best bang for buck padding before I put the orig carpet back on.
FoxyMama
