Qi Wireless Charging (OEM Style)
sure74
Goal here was to add a Qi wireless charger that could be mistaken for an option that came from Toyota or just not be seen at all.
The lower bin in the center stack seemed like a logical choice. My phone fit there pretty well (also tested with a note 4 which is just over 6") and it is easy to grab the phone from that spot at stoplights and such. Also, the plastic there is pretty thin and the 12V power outlet was the perfect spot to grab power for the mod.
Parts for the mod were actually pretty cheap, the whole thing came in under $30. I used the PowerBot PB1020 Qi Enabled Wireless Charger for its wireless charging component and I used the HitCar DC 12V to 5V Power Inverter Mini / Micro USB DC 3.5 Hard Wired Converter Kit to supply the power. I also used an old Digital Optical Audio cable to redirect the LED from the charging board and I used some Extreme Mounting Tape to secure the charging board to the underside of the bin.
Here you can see where I grabbed power from the 12V power outlet. I removed the protective cover, soldered the wires from the HitCar DC 12V Inverter and slid the cover back on.
I removed the board from the PowerBot Wireless Charger to mount it to the bottom of the bin. The other side of the board has the wireless charging coil which has to be as close to the bin plastic as possible. Two layers of the extreme mounting tape provided the perfect spacing. I carefully trimmed two layers of tape to fit around the coil and applied it to the bottom of the bin.
The LED indicator is soldered to the board and I was definitely going to need to know the status of my new charger. I used an old optical audio cable to redirect the light from the LED to the top of the bin. In this pic you can see how I used hot glue to fix the cut end of the optical cable directly in front of the LED to pick up the light.
The other end of the optical cable is attached to the top of the bin using hot glue. The original connection was perfect since the exposed core is about as long as the bin plastic is thick. I just needed to make a pin size hole in the top of the bin to let the light shine through. Behind the optical cable you can see the power inverter which is also attached with mounting tape.
Added bonus, once I disconnect the the AUX and 12V power outlet connectors the unit comes out same as before the mod.
The finished product. When the unit is not charging the LED is green. It actually makes for a pretty nice little light for the lower bin. When it is charging (most of the time I am in the truck) the light is blue.
So far so good. It's been installed for a month or so and I have had no issues with overheating or my phone not charging. I just throw the phone (or any Qi enabled phone that fits) in the bin and it charges.
Let me know what you think & thanks for checking out my mod.
Was planning this out 2 weeks ago with a 3d printer to mold around the specific Qi charger... my current charger is picky on charging depending how my phone is sitting. Iwas worried about the extra layer of material if its solely mounted on the underside. My focus got shifted elsewhere, but you have renewed my interest
Very nice, been thinking of a way to use a wireless charger in the 4runner and you just gave me the idea.Thanks
With the board out of its original case you are not charging through any more or less plastic, essentially using the bin as the case. Also, if you look at my pictures you will notice that the board is mounted a little to one side. While test fitting I had the bin and charger board hooked up in the house and I just moved it around until I found the best spot. For both of the phones I tested the charger worked better skewed slightly toward the bottom of the phone.
Thanks JET4
Do you have a case on your phone? I feel like I need to search around for another Qi charger that will fill up more of the space,. Thanks for pioneering this!
I had thought about it after seeing the one built into the Tacoma. Now you made me open up my muti-coil charger. Nice, its one piece. Now I will have to see if it will fit under there.
I see mine is 5V. Is that what the power inverter you refer to is for?
Great Mod and great write up.
Thanks Slow
tslycord, I have a slim jelly type case. See TK-422's post, I think his charger is just what you are looking for.
TK-422, that multi-coil charger is pretty cool and I think it will fit for for sure.
Dude,
Love this MOD, I would love to get rid of the wires in my runner. Very Clever Indeed.
Will be working on this soon enough.
Thanks DenverTrailRunner
What brand/ model is that?
Choetech
It's nice because you can just toss the phone (Note4, S5, S6 in my house) on them in any direction and they will charge. I have two of them so one just might go missing.
I pretty much stick to the lightning charger at home but on the road there is no hurry to charge it.
Amazon order arriving Friday! Only thing now is figuring out what to do about the status light. I don't want to hack up a perfectly good audio optic cable.....
This is what I was thinking. You open it up and remove the plastic chrome trim ring. Use the inside as a template on the bottom of the tray. Very carefully cut it out. I mean VERY carefully.
Here, I made a sample out of cardboard in a few minutes so it gives you a rough idea. Snap it together with the tray replacing the ring and I imagine it would look factory with the qi logo and a grippy surface. Bonus points for the LED being right there on the surface.
The charger is just a little too large to fit like my idea above. I will do like Sure74 and just hot glue it from below. It just fits in there naked.
AndiGarage
