Say you locked your center diff in 4x4 low. 3 wheels are on ice one wheel isn't. You are on a incline also.
Will the 4x4 system transfer all the power to the wheel that has traction??
The cool thing about the 4Runner's 4-wheel drive system is that you can be in 4-Lo without the center diff locked if you choose. That's an option that not many 4-wheel drive systems offer.
I understand the center lock 50 / 50 option, but don't quite follow what happens in 4LO when used normally and how that differs. Can anyone explain??
so all that being said, when is the best time to lock the center diff? It sounds like its better not to in the ice, if like the poster said 3 wheels are slipping and one is not. what scenario(s) would be the best to lock the center diff?
for a month or so next Spring I'll be driving on the beach a lot, and hadn't heard using the center diff was a good idea. Can you be a little more specific how it helps on sand?I drive on the beach for a couple weeks each year. I always lock the center diff prior to going out on the beach. Locking the center diff turns off ESP -- spin protection. That's not an issue on the beach.
It allows a little more slip of the tires before the traction control/spin control starts braking and shutting down the throttle.for a month or so next Spring I'll be driving on the beach a lot, and hadn't heard using the center diff was a good idea. Can you be a little more specific how it helps on sand?
To get all the torque to one wheel you need locking differentials in both axles. Land Cruisers had that option from '91 to '97, Jeep Rubicons, and I think there might have been another vehicle or two. My '97 Land Cruiser was a tank with everything locked, but you could hardly steer it, and I wouldn't want to get over maybe 10mph like that. The modern alternative of using traction control to transfer torque is easier to live with for a daily driver.
That's not really true. In an 80 series land cruiser with the center diff locked and both front and rear diffs locked - each wheel is mechanically bound to the driveline and thus is receiving 25% of the rotational force.
With everything locked, and three wheels in the air, the wheel on the ground would get all of the torque, while the three in the air would rotate with the wheel on the ground, not spinning free. So the wheel with traction in this situation would get all of the power, which was the original question.
Thanks to all for replies in this thread....very helpful.
I think we are really saying the same thing, just trying to avoid the OP thinking that 100% of the power goes to one wheel in a fully locked rig. Just as a locked center diff takes power 50:50 front to rear axle, front and rear lockers take that 50:50 and make it 25:25 at each wheel front and rear.
