Question about slip yoke
Johns06yota
Member
I had a question about the rear driveshaft slip yoke after my visit to toyota yesterday. They were able to fix a vibration issue I was having by tightening a loose bolt but they told me my rear driveshaft needed to be replaced due to play in the slip yoke. (rotational play)
I held off because I had read about people greasing their driveshafts to fix vibrations/clunks but mine doesn't exhibit any of these symptoms. Is this normal? Does it need to be replaced?
What bolt did they tighten? What kind of vibration issue?
The slip yoke thing seems to be a manufacturing defect with our driveshaft. I assume the splines and mating surface have some kind of surface finish or tolerance issue. The result is that without a LOT of lubrication they tend to kind of jam up under load then make a "clunk" when it breaks free (normally when accelerating from a stop or just before coming to a stop).
Not sure about your issue but I'd assume it's got the same problem as everyone else's 4th gen. Without understanding what other issue they "fixed" then it's purely speculation.
Mine needs to be greased every couple of months..
I'd find a good heavy grease before replacing anything, a light grease will fling off in a day all you will smell is it burning as it hits the exhaust.
Thanks for your response! The bolt that was loose was for my lower control arm on the driver side. sorry for not explaining that. They had just said when they were trying to find the noise that the slip yoke had some play in it. I havent ever had a clunking noise from it but I just wanted to make sure it wasnt going to detonate at highway speeds haha. I have an upcoming trip to Florida so just wanted to play it safe
What kind would you recommend? I have had it greased before but I was never the one who did it. I take it that I need a grease gun due to the fittings?
Sounds kind of sketchy to me. Basically, every 4th gen's rear driveshaft needs to be replaced. They made a TSB and I think replaced them under warranty for the Lexus (same drivetrain) but us 4runner owners were left out in the cold. I think there's been some attempts to get a class action or something else to get them done without much success. If it was killing people they'd jump but just pissing off a bunch of owners of used vehicles doesn't have a lot of teeth.
I use Mobil1 synthetic grease because that's what I have loaded in my gun. About any kind of chassis lube will work. There are a handful of threads on here with people extolling the virtues of various lubricants. At the end of the day I don't think it really matters on this one. The slip yoke moves a whole inch or so in it's travel so it's not really a "high wear" item. That's why I find it sketchy they're trying to tell you it's worn.
If it hasn't been done by you or someone else lately the driveline needs to be lubricated. Both u-joints on each shaft and the slip yoke have grease fittings. Put grease in the joints until you see it pushing out some of the old grease (think playdough fun factory). For the yokes there's a lot of info. I put maybe 10 or so pumps.
If you put enough that it starts to fill the void between the two parts (you actually see the shaft parts start to press apart) then drive very carefully for the first few miles and give the grease some time to migrate around in the cavity. Maybe the dealer went ahead and serviced the driveline as part of the "clunk" service. Check your receipt or ask the service manager first.
That may be my issue because I'm nearing 157000 miles and I know its never been replaced. Granted I don't get any noise from it that I can tell but you never know. When that bolt was having issues up front I was also getting a very pronounced pop noise that could have been the driveshaft. It has been greased some though. Before I had it I don't think it ever was. Should I just bite the bullet and order the part and replace it myself? It looks relatively simple
Lots of 3rd gen guys with over 300K on the original driveshaft. I doubt it's an issue. If you're anywhere near Raleigh maybe swing by East Coast Gear Supply and have them take a look.
I can't recall what grease I finally got to stick, it's in my grease gun which I can't open until the tube is empty or else I will have a messy issue.
My apologies for not being able to offer more help
4runners use a fixed yoke. Not a slip yoke.
I had to look that up. Bad terminology I guess. So our T-case has a fixed yoke but the driveshaft both front and rear also have slip yokes, or is there a different name for those?
H.Sikina
