Question about the oil filter on top of engine
General Lee
I changed the oil in my 05 runner V6 and when I took off the factory filter oil just layed in the housing. I soaked it all up with about 8 paper towels and then saw what looked like a drain hole. Problem is oil wasn't draining. Is this normal, am I missing something here? What do you all do to get the oil out?
It should have drained through that hole....maybe you had something blocking it?
There's a rubber cap under the drain hole which you can remove and insert a fitted tube or a small container underneath to catch all the oil. Don't remove the cap unless there's something underneath there as the oil will drip onto certain engine parts (I can't remember if it was the drive belts or not). I normally wouldn't need more than 1 or 2 paper towel to soak up the oil left in the housing. Are you removing the oil filter shortly after shutting off the engine? I usually shove a paper towel in between the bottom portion of the housing and the oil filter and then slowly unscrew the filter. It will soak up most of the oil coming out. I also use a cotton swab to clean out the oil in the drain hole and cap.
I probably removed the filter after about 15 min of the engine being turned off. I only let the motor run for a few to warm up the oil. The housing filled approximately 1inch from the edge then it would have spilled out. The wife has the runner right now, when she gets back I'm gonna have to see if that hole is clogged.
I don't recall seeing a cap for the drain hole. I saw a tube from under the oil filter housing that ran somewhere to the motor I assume. Thanks for the feedback guys
My '03 came with a 'rubber' cap covering the drain port under the oil filter mount. I have found that one of the one quart plastic containers will just fit underneath this port and catch any oil that leaks from the old filter. I have long since lost the rubber cap, so I just make sure I have the 'catch' bottle in place before I loosen the old filter when changing it.
:smash:
Well I looked closely and come to find out there is a rubber cap about an inch and a half long underneath the drain hole. I guess being in a hurry trying to get out of the heat and looking at it at a wrong angle I thought is was a tube leading towards the motor. Damn, what an idiot I am. Thanks for the help :D
General Lee said:
:smash:
s'OK, thats what we're here for.
