Question about the pan hard bar
nissanh
Senior Member
When I installed tall 99 springs I had a horrible time to get the pan hard bar aligned.
I there an easy way to get it lined up with the frame and suspension mounts?
thanks
nissanh
If you put taller spring on, it will not line up quite the same and the axle will be offset slightly to the passenger side. No way around it unless you get an adjustable panhard bar or a drop bracket.
Where to buy a drop bracket?
Hi,
Thanks for the information. The way I installed it last time (took about an hour) is to jack between the axle and the body on one side, and the other-end of the axle is forced towards the body.
Can't I use a strut spring compressor go get it in?
Also, any link for the drop bracket would be very helpful.
thanks
