question for those with abs
giovannie23
does your abs modulator valve make a 2-3 sec loud groaning noise when key is turned to "on" postion ( with engine off)
i was wiring up my cb to the in cabin fuse box
and noticed this sound whenever i turn key to on position
im not sure if it was there before and never noticed it
wanted to see if this a normal thing or not
its a 97 thanks guys
this is the part im talking about
My trucks abs does this with the key on, however it is an 02 and I know the braking system, as far as abs goes is different on newer trucks. I think the sound that mine makes comes from around the brake master which, on newer trucks is where the abs module is
Sent from my ONEPLUS A3000 using Tapatalk
Yea it kinda sounds like a motor turning on and then dieing
I have no abs lights on
It doesent seem to make the noise if I start the engine
only if I have to key to the on position for a couple seconds
I have the exact same sound in that area with ignition on (engine off). It goes away in a second or two. Been like that for past 7 years.
I used to have abs, I had like a 6 pack! Then I started drinking beer. I no longer have abs. Sorry I can't answer your question. Wait... different kind of abs?? My bad, time for more beer. :beer:
seltzernator
