Question in middle of lift install.
mace.
Driver side is done up 2.5 in from stock. Do the CV angles look to severe or is that ok?
3 corners are done. The front seems to be sitting pretty high. Plan is to finish the rear tomorrow and go for a quick drive and see if it settles some. If it doesn't settle some I'll drop the front some before the alignment on Monday.
Finished everything up and it's getting aligned at the moment. On the way over I did notice a slight clank / thud from passenger rear area. It doesn't make a sound if both sides move up and down together only when passenger side hits a bump. I'm going to get under there later and re-torque everything again especially the sway bar.
Where are the final pics?
Soon, soon. I have more parts on the way. I wasn't fond of the mounting brackets for the Billy 5160s so I ordered the billet ones. Will try and get some pics tonight if it's not too dark. If not I will definitely get some Friday morning as I have the day off and am getting my Duratracs mounted on these. It looks pretty anemic now in stock tires.
