LV4R said:
I am curious if anyone with a Xenondepot HID kit knows how the relay is used when installing the kit. I am specifically wanting to know how to wire my HIDs straight from the battery so that they turn on with normal use of the headlight switch. I am not too keen on the current setup that uses the existing headlamp wiring.
Thanks in advance for any help!
How a relay works. This
diagram shows the connections for a relay.
There are at least two "versions" of the Xenon Depot (XD) harness that I know of. The relay in XD kit acts like a switch which is triggered by the OEM factory headlight socket and power is drawn through the positive and negative hookup through the wire harness preventing overloading of the factory headlight wires.
The first one has one relay, fuse and one OEM headlight harness plug that goes to the factory headlight socket used to trigger the relay to power up the HIDs. The harness consist of two plugs to the HID ballasts, a plug to the OEM headlight socket, a lead for positive and negative hookup, one fuse and relay.
The second harness is essentially a seperate harness for each headlight. XD provides two harnesses, one per side. The harness consists of a fuse, relay, positive and negative hookup, OEM headlight socket plug and plug to HID ballast.
Depending on which version is shipping, XD wiring harness(es) has the HID ballast(s) drawing power from the battery or where ever the postive and negative hookup are attached to. The OEM headlight plug is the trigger for the relay, so the factory headlight socket is activating the relay which is powering HID(s) through the positive and negative hookup.
I got the first version harness with my XD kit for my other car in January 2006. The second version harness I got in October 2006. I'm not exactly sure when XD made the switch between versions. The harness in 4RunnerRon write-up linked above is the first one.
Personally, I prefer the second version of the harness, there are two relays and fuses so each headlight are wired independently and both OEM factory headlight sockets are used--you don't have to tape one side up. The downside is of the second version is both harness are equal length, so for the driver side headlight there's a nice bundle of wires to be tucked away. The first version has the two plugs to the ballasts of unequal length.
You can try
emailing XD and see if they can tell you which "version" harness they're shipping.
