Quick question.
nmis300
Will a 265/75/17 tire fit on a stock 04 V8 Sport 4X4 4Runner? Found a good deal on some wheels and tires and was needing to know. Thanks for the help.
Do you mean 265/70/17?? If so, then yes it will fit. Only minor exception is the BFG AT KO in that size will cause minor rub.
No I meant 265/75/17 - thats what the post said - they were on a Tacoma.
Sorry, can't help you...never seen that size before. Well, i believe that 265/70/17 is the biggest size that you can have on a STOCK 4runner without rubbing. So, 265/75/17 will likely rub.
I do not believe that size is made any more. Double check with the person selling the wheels. Taco popular size is 265/75/16
265/75/17 is 32.6" and will be a real tight fit without a lift. Most owners here run 255/75/17 with a 3" lift.
I found out it was a typo on his part - it is a 265/70/17 with Terra Grapplers. I think they should fit without rubbing.
