Frontier719
I just wanted to confirm--I read the writeup on yotatech, but my chiltons doesn't have the spec on it
is the deflection for the alternator belt 1/2"?
The deflection is "make it tight".
I recall reading no more than 1" of deflection from somewhere. It's worked fine for me.
Rules of deflection (how much movement up and down in a belt):
If pulley centers are > 6 inches apart: 1/4" to 1/2" deflection between the pulleys
If pulley centers are < 6 inches apart 1/4" deflection between the pulleys
The power steering needs to be about 1/4" deflection, if you don't, then it will squeal when you turn sharply in a parking lot. The alternator needs to be about 1/2" deflection. The A/C needs to be 1/4" deflection.
I think that's too loose, especially on a new belt. The official spec requires a tension gauge and is different for new versus old belts. I actually own one I saw on eBay, but it's virtually impossible to use it unless the engine is on a test stand. There just isn't room. I go by feel, but I can't really define it. But to the extent I can use the gauge, I'm not far off.
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/ch5vzfe/chasy/ovi.pdf
I think the YotaTech thread has it about right:
How to: Change Drive Belts 3.4 L 5VZ-FE - YotaTech Forums
All three of the drive belts are adjusted with a screw adjuster/tensioner
as convenient as that type of adjuster is, they make it VERY easy to over tighten a belt.All three of the drive belts are adjusted with a screw adjuster/tensioner
