Quick Tire ?
RadRunner
Dont know much in this area, seeing if someone can help me. I have a 99' 2WD with the 15 in. steel wheels the stock tire size is 225/75/R15, I want to put on a tire that a little wider 235/75/R15. BFGoodrich All-Terrain T/A KO Will there be any problems? Thanks.
There def won't be ny problems. My truck came stock with 265/70s. I tihnk you should get 255/70s, these are cheaper and bigger.
http://www.tirerack.com/tires/tires...SR5GRAT2&vehicleSearch=false&fromCompare1=yes
I'd go with 31x10.50-15's. They'd fit perfect and be pretty cheap. And they'd make a substantial difference in looks.
265/70s are basically 31x10.50's. The 31s are slightly larger, I think.
You guys are all talking funny... 235... wow.
He needs 265's.
You should also consider changing to a 16 inch wheel, better look, better performance, much larger tire selection (may be a bit more expensive but so worth it), and the ability to do tundra brake upgrades.
265/75/16 brother.
you guys are all talking funny... 235... Wow.
He needs 265's.
265/75/16 brother.
and much more expensive!
no
there will be no problem i did it to mine it came with 225/75/15 and i got 235/75/15 and you could go with a 31*10.5*15 if you wanted just use more gas
