R150F and R151F compatibility
nathanroyse
I’m looking to replace all bearings and seals on my R150F transmission. Everything I’ve seen talks about how they’re basically the same thing but with different 1 & 2 gear ratios. That being said, would a bearing/seal kit for a R151F work to replace the ones on a R150F? I’m asking because the only bearing and seal kit I can find is for a r151f.
I believe so..
That's a loose answer, though.
You will have better luck on the Marlin Crawler forum for this question. R series experts over there..
Best I can remember, the 151 gear set is simply girthier than the 150, and the 1st gear is super low.
If you head over to the marlin boards, you may want to inquire about R154 bearing upgrades (caged bearings etc)-- not sure if all of that is applicable to a 151, but they'll know how to make your trans bulletproof.
I believe so..
I’ll head on over. Thank you very much for the info.
AndiGarage
