StreetCreeper
Still confused here if the transmission is now separated from the rad then how could this happen again. I have the tranny cooler with lines here at my place just never got around to putting it on. This way from my understanding if the rad is compromised it shouldn't matter. if I attach the inlet and outlet lines together with a hose, where the tranny lines used to be. the rad will run itself the transmission will have its I own cooler with its own fluid. Is there something im missing here.
Both tranny and read will be flushed as well.
1) Yes you can run your tranny cooler that you already bought and bypass the old half broken radiator that now has ATF residue in it. You will then have a shitty/dirty/broken radiator to keep your engine cool while you potentially overheat your transmission depending on how you use your truck after you install the stand-alone tranny cooler as well as potentially run it with perpetual cold fluid during the winter depending on where you live and how you drive. But hey, you won't have to worry about the pink milkshake — again.
2) You can also buy a new radiator and use your stand-alone tranny cooler that you already bought, and bypass the new radiator's built in tranny cooler. Your engine will thank you but your tranny may not for the same reasons in #1) above.
3) You could buy a new radiator and use the internal tranny cooler as designed without much worry of a pink milkshake any time in the next 100,000 miles. Your engine will thank you and your transmission will have a fighting chance of surviving the first pink milkshake.
4) And finally, you can buy a new radiator and use the stand alone tranny cooler you already bought, in conjunction (read in-series) with your new radiator's internal tranny cooler. You will remove nearly all the possibility of a pink milkshake (but not all), while helping your engine stay cool. You will also be helping your transmission stay cooler than if you had just run the stand-alone cooler by itself, in addition — you help the tranny fluid warm up to operating temp quicker when it's cold out. So now your engine will thank you and your transmission will too.
Like the others, I would recommend #4.
