Rad Rubber splash guards for 3rd gen?
velomatt
Member
I just received a set and the fitment is terrible.
Anyone have any luck with Rad Rubber or did I get a bad set?
I got booted from the 3rd gen. Mafia for asking this same question.
My experience started when it took months to get them, zero customer service. Fitment was okay. Had to make some adjustments. Still wish they covered more area. However the materials seem to be top notch.
This would be a good one for the Durabump dudes to make.:gun6:
I used their 1" BL set. I got it to work, but it was not nearly as good a fit as OEM. And the supplied cheap fasteners were horrible, I ended up using some old OEM fasteners I had laying around.
I am using their extended ones for the 1 inch body lift. Honestly, I thought they were really nice for the money and mine fit fine, maybe you got a bad set? Although I'd think they would all be identical.
They didn't even last a year. Rubber is ripping along the edge. Not even near a mounting hole. These are a joke!
Mine have also cracked at all the fastener locations. I did contact Eddie at Rad Rubber, he said that this is highly unusual and sent me free replacements, which I have not yet put on. To be honest, I'm skeptical, it looks like the same stuff. Interestingly, the new pads came with instructions recommending soaking them in some fluid film (IIRC) to keep them pliable.
I'm seeing the future, which will be me making my own splash pads :).
Is this needed because your old splash pads broke? Or are these upgrades vs. OEM?
It's because of my 1" body lift :). The originals were still perfectly fine, but I couldn't find a clean way to make them work with the body lift. I preferred the material of the originals over the replacement rubber pads, and indeed they look fine after 24 years, while the replacements are falling apart after one.
They look nice in your hands, but the hole spacing is all wonky, and after 1.5yrs, mine are all dry rotted and cracked along the edges. They become brittle with age.
Agreed with a previous poster- Durobumps or another mfg should make a quality set :)
I bet they are made of neoprene or similar. Need a set made with fiberglass reinforced plasticized PVC instead.
The Rad Rubber shields are a lot thicker than OEM. I wonder if the thinner material is better, as it would be more flexible? I'll be the first to admit though that soft goods are not my engineering forte.
maybe not, but with practice grasshopper.....
add it to your list of items you sell
thanks for that link, wonder if there is a pdf on making them for the 3rd gen like there is for the 4th gen
I don't think there is a pdf but using your old ones as template and cutting them out should be easy.
that is if a person had old ones. my 2001 only has little shreds left
First Congrats on the highlander find
Some' tracing paper a pencil might work or just taking a ball park piece and trimming it. let me know and I can trace mine on paper and mail it to you.
seltzernator
