Radflo 2.5 Lower Shock bushing vs bolt size ?
Greydog
Member
Hi guys, I had my 2.5's installed Friday (by a shop) and they are a great setup ! However I am getting alight clunking noise/feel on pavement seams or driveways.
Does anyone who's installed these know if the factory lower shock bolt is truly the correct size for the Radflo bushing ? Thinking this may the noise I'm hearing.
Also going to move/tap the swaybar slightly toward the drivers side, looks like this may be a noise maker too as I think I see the bottom edge of the spring may be making contact with the bar under compression perhaps (it looks a bit scraped,not touching when as it sits but is closer than the passenger side).
Last, anyone installed these with ADDCO front bar ?
Thanks.
Hey guys, anyone experiened any clunk/rattle over low speed bumps from their front CO Radflo's ?
Do you know if the lower bearing on the Radflo 2.5 is sized properly to the stock lower shock bolt ?
Thanks !!!
