radiator dimensions
ojaipride
I have an 89 4Runner 4x4 that originally came with a 4 cyl that was later swaped to the 6 cyl 3.0 L engine. The radiator was never replaced however. It now is in dire need of replacement due to corrosion and I would like to upgrade to the radiator for the larger engine. There is very little wiggle room so I want to get the dimensions of a stock radiator that came with a 4Runner with a v6 to see if it will fit, anyone want to break out the measuring tape for me?
I just need to know the length, width and height of a stock v6 radiator from and 86-89, or if anyone has done this before and knows that they are the same size?
Since both engines were available in the same body, simple logic would say both radiators fit.
Or you could use a 22-RTE radiator, that's what I have cooling my little 22R.
