Rapid Blinker
airbur
Anyone have any idea as to why all of a sudden the left-turn blinker light blinks about 2-3 times faster than the right blinker? I'm at a loss. Thanks!
Means you have a blinker out. When the draw from your blinker runs below the range of power necessary, then it blinks rapidly to let you know its out. Check the front/rear blinker of the side thats blinking fast.
PERFECT!! I knew it was something easy. THANKS!!
KarenCaren said:
lol. I didn't know this. how long will this happen?
___________
If you ain't first your last!
My Blog: wheelywheel
'bout all the time that your truck has one turn signal light bulb out. ;)
It's just a simple indicator if one of the turn signal's light bulb is out.
Rapid Blinker - Continued
OK-
Anyone have any ideas, I had thison the front RT, tried replacing the bulb with new ones and am not getting any power to the DRL or signal? All other signals and hazards work so I can't see it being a fuse. I would also think that if something was shorting out, then the fuse would blow. Could there be a relay, resistor or something elso specific to the front right DRL/signal that could be causing this?
Any help is appreciated.
BBB
Re: Rapid Blinker - Continued
BostonBeachbum said:
... Any help is appreciated.
Is your rear turn signal working? If so, then look at how you have the replacement seated in the holder or how the holder is seated to the harness connector. I suspect a connection issue.
Re: Re: Rapid Blinker - Continued
Yes rear is working, I've tried the connection several times with different bulbs and no luck.
