RAS sensor adjust pics
southpaw2324
Anyone who has lifted their fronts and adjusted the RAS sensor for the back please post pics here. I wanted to see how much lift you got out of yours.
I did the daystar 2.5" front and adjusted the sensor in the rear all the way up but i feel my back is still sagging a little.
You can remove the link and unscrew the ends a bit for some added length. I've done this on mine. I believe it's referenced in the FSM, it's attached at the bottom of the suspension FAQ sticky.
There's also another method of adjusting the rear that doesn't involve the sensors. I've never researched it, but seen it done a time or two. Haven't seen it on a 4runner, but on a Lexus GX470 which uses the same system.
2001ATL
