RatRunner16's 2016 TEP
RatRunner16
Bought my 4Runner back in October and have slowly adding different things to it.
First added Rigid SAE's in the fogs along with a Cali Raised 32" combo bar behind the grill
Finished the install of my switch panel made by Front Panel with flush mounted scanguage, switch pros, camera override dongle switch, cigarette lighter, dual USB port, and a indicator light for the secure idle
Express
First downloaded the Front Panel Express software and spent a good chunk of time measuring all the individual pieces and the layout. In the end I received this peice of aluminum in the mail a little over a week after I hit submit
I then pulled out the head unit and set off on dremeling out the rear of the OEM cubby space so the new panel wouldn't have any clearance issues (failed to take a picture of this) the new panel is flat in comparison to the OEM and had to be spaced out about a half inch. I then powder coated it and went about wiring it up with the help of a friend.
1/23
It looks so excited to be a part of your build.
Been a while since my last post...time to start updateing.
Went into the dealer about a month ago due to a constant blinking 4wd light. After some time they diagnosed it as a failed actuator in the front differential and replaced the part.
I have since added Metal-Tech 4x4 sliders
and
Spent a few days traveling through Death Valley
