Re-gearing and speedometer
velasquez.huaa
well at this point in time i am now certain i can clear 35x12.5x17's but im currently running 285/70/17s, i was wondering if anyone has re-geared the rear end on a 4th gen 4runner and how difficult it would be or the write-up for it would be lovely, also does anyone have the fix for our speedometers when bumping up in tire size :crybaby:
i have done a lot of research and if i were you i would just sub it out. i am a very capable mechanic and can't justify all the one time use tools. I also priced out that the work is a little over $200 if you remove and install it yourself. here is a link of what is involved in re gearing.
Toyota Gear Installs
eastcoastgearsupply.com
I haven't regeared yet because i do a lot of freeway driving and its probably gonna hurt me more in gas.
Some days I wonder why I bother writing stuff if people never find it... lol
[MENTION=126906]velasquez.huaa[/MENTION]
http://www.toyota-4runner.org/4th-gen-t4rs/178078-speedohealer-v4-4th-gen.html
As for re-gearing, it's not too bad a deal depending on how big (ring gear wise) you go. Usually you want to do both front and rear differentials so that in 4WD the transfercase isn't working too hard; but starting with the rear first shouldn't be too bad.
Post Note-
I have not done the math, but I don't know if re-gearing will affect the speedometer as much as changing tire size does since it uses wheel speed for the data value. Anyone actually done the math on this?
I'm sorry, but that write up is perfect, thank you!
Post Note-
