Read defrost AND recirculate buttons
KYBubblehead
Rear defrost AND recirculate buttons
With winter approaching, I need to fix this,,,
BOTH buttons do not work (no lights either). I took off the panel and saw a PC board.... should I just go to the bone yard and get a replacement panel? I feel it's the board, since neither button on it works...
I bow the collective wisdom of the forum ...:hail:
You can replace the bulbs if it's just the lights that aren't working.
If you're sure it's the panel you can pick one up for $50 just about everywhere. I had to for a different issue and got mine on eBay. Be aware that sellers send them w/o bulbs so hold on to yours!
Sadly, it isn't just the bulbs.... the rear window doesn't defrost and the display for inside/outside air doesn't change..
how were you able to resolve this?.. after having my evaporator replaced, i noticed my recirc button lights up when the inlet is open and off when the inlet is closed..
am thinking something may have been swapped during the evaporator work
Mike Sargent
