Read defrost AND recirculate buttons
KYBubblehead
Rear defrost AND recirculate buttons
With winter approaching, I need to fix this,,,
BOTH buttons do not work (no lights either). I took off the panel and saw a PC board.... should I just go to the bone yard and get a replacement panel? I feel it's the board, since neither button on it works...
I bow the collective wisdom of the forum ...:hail:
You can replace the bulbs if it's just the lights that aren't working.
If you're sure it's the panel you can pick one up for $50 just about everywhere. I had to for a different issue and got mine on eBay. Be aware that sellers send them w/o bulbs so hold on to yours!
Sadly, it isn't just the bulbs.... the rear window doesn't defrost and the display for inside/outside air doesn't change..
how were you able to resolve this?.. after having my evaporator replaced, i noticed my recirc button lights up when the inlet is open and off when the inlet is closed..
am thinking something may have been swapped during the evaporator work
