Real time. Rear hatch motor no power
All this is a good info.
My hatch motor also sometimes quite and just wouldn't pull the hatch into locked position, but also wouldn't release the hatch.
Same time my driver window loses the auto-open/close ability.
And YES, the 30 min disconnected battery reset works and and hatch motor lock works again. But I'm getting tired of having to continuously reseting it and would like to see some more permanent fix.
Is this a sign of rear ECU failing? Do I need to replace it? Any troubleshooting steps?
Did you figure out what was happening? I am currently having the same problem.
hi folks, i am having the same as ukrsindicat above on my 2004 4RunnerSR5. How do we troubleshoot if it is the ECU or the actual motor? would rather not buy both
Did you figure out what was going on? I am having the same problem.
Hey, brother. Sorry for late reply.
I did figure it out. It was all in the hatch lock assembly. I replaced it and everything worked just fine
Something else.
That rear latch seems to get mucked up over the years.
Cheap to replace the mechanism nowadays too... Under $100.
Dang, that's totally affordable. What is the thing called? I'm looking on Claremont Toyota parts diagram and found options.
This one is called "lock assembly with motor B" for $253
2003 Toyota 4Runner SR-5 Sport Edition 4.7L 4WD Lock assembly, with motor b. Body, door - 6911035090 | Claremont Toyota, Claremont CA
this guy did a great job Stuck open or closed rusty Tailgate Latch fix for 2003-2009 Toyota 4Runner - YouTube
Saw this on eBay and the latch is brand new AND it comes with an emergency latch release rope!!!
Toyota 4Runner Avalon Tailgate Latch power Lock Motor Genuine 69110-35090 | eBay
I bought one of these back in October. Still working as it should and way cheaper.
Amazon.com: Bicos 69110-35090 69110-35062 Rear Tailgate Liftgate Lock Latch Actuator Assembly Compatible with To yota 4Runner 2003-2009 Replacement# 69110-35060 6911035090 : Automotive
Did anyone solve the riddle?
Hello all,
I see quite a few people battling the rear window paralysis. Did anyone actually solve it and care to share?
Even if it was a dealership visit... what did they do and what did it cost?
I finally took the regulator motor out and measured all 6 pins in any combination. None of them had transmission. Not sure if that's a good thing. I want to try and connect it to a battery to see if I can get it to move.
Anyone know which pins are ground and which I have to put the positive cable to?
thanks folks!
