Real World MPG with 5th Gen?
It's a 2015 Limited with almost 27k on the odomoter. It's not much but I put roughly 30 miles a day round trip.
How many miles are on yours?
only about 800 lol. I'm assuming then the problem is the stop and go traffic of your regular commutes. I remember when mine was stuck at 15mgp for a while I was pretty bummed.
Damn 9 to 5 job killing my mpg.:uzi: I did take a long highway trip and was getting about 19mpg, that was nice too see.
I just had my 5,000 mile service, I never reset the MPG calc on the rig. so my average over actually 5,250 miles was 18.3 mpg we'll see what the next 5,000 miles brings. my highway/city mix is about 60/40
I've got a 2010 LE with the Daystar spacer lift, 255/75R17 KO2's and the Prinsu full rack and I'm averaging around 14.5mpg. My commute to work is pretty even between freeway and city.
I accidentally posted this in the 3rd gen thread first :doh:
Year: 2018
Tire Size: 245/60/20
Gear Ratio if you know it: stock
2WD or 4WD: 4wd
Modifications that affect MPG: none
Current highway fuel economy: 18.8 mpg
Automatic or manual transmission: auto
4 cyl or 6 cyl: 6 cyl
Octane of fuel: 87
We just picked up our 4runner so after our trip to Cuyahoga Falls in Ohio (from Western PA) we have about 400+ miles on it. Was just over 100 miles each way. Average highway speeds were about 67-75 mph with a couple wot pulls away from the toll booths. :D
I set the trip at the pump before we left so I hard calculated it and reset the dash readout... dash readout was about 18.6 and hard calculated was about 18.8 so it's pretty on the money!
Anything I've ever owned seemed to improve power wise and fuel mileage wise right around 5,000 miles. Who knows, maybe I will see in the 20s once I switch from the LE 20s to lighter weight 18s with a slightly larger OD tire to lower highway rpms :)
With 265's load range E bf KO2's and a Shrockworks front bumper and warn I'm getting 16.8 by hand at 72 mph and I travel a lot for work.
285*70*17
Method wheels
3 inch lift
Sliders
I get 16 back and forth to work which is 30 miles round trip, did a Mojave trail run not long ago and got just over 18 to the trail and 16 back with a head wind the whole way
Sent from my SM-G950U using Tapatalk
2016 Trail Premium with Icon stage 2 lift, 285/70 17 duratracs, shrockworks sliders, and GOBI stealth rack. I do about 50/50 city highway and am getting around 12.7 mpg according to the computer using 89 octane winter gas. I haven’t hand calculated yet though. I honestly think the GOBI rack is my biggest issue with the poor mileage.
Going to be putting on the SSO slimline bumper with synthetic winch on soon too so that is going to make it even worse. Thank god I live only 10 minutes from work!
You might actually be close to 1mpg better than that if you haven't had your computer reprogrammed for the taller than factory tire (if necessary on Toyotas, I'm not sure). Your odometer will be off by about 35 miles for every 1k you travel.
Splitting hairs really :lmao:
I have a '15 TRD pro with a gobi roof rack approx 35k miles on ODO, accelerate like a turtle off the line, per car computer I avg 18MPG. I'm probably split 50/50 city hwy driving. I used to avg 16.3MPG when I was heavy on the foot but I drastically change my driving style to really see how good of a MPG i could get. I've been avg 18MPG for the past few months now so I know I can be consistent.
TRD Off Road Premium, Radflo suspension / lift, stock tires, sliders and now about 1,000 miles on the odometer
Went out to Vegas and back with some headwinds (traffic in San Bernardino area) on the outward bound leg; might have been a tailwind on s/b leg but also had very little traffic. Kept cruise control at 70 MPH most of the time.
Calculated MPGs
276.3 miles 13.4 gallons Arco 87 Octane 20.6 MPG
276.4 miles 12.4 gallons Arco 87 Octane 22.4 MPG
Performed an odometer check of 11.0 miles versus GPS measurement of 11.2 miles so only a 1.8% error
I calculate mine by the odometer and gallon readout on the gas pump. I average 19.8 around town hand calculated, and my dash says 19.7.
I run stock size KO2s at 38psi.
I calculate mine off the pump and odometer read out as well. Ever since i put on the heavier E-rated 285s my mpgs took a big hit I was averaging around 17-18 mpg before the tires. Now I average about 15.6 or so. I also have a stage 2 Icon lift. So that probably contributes to it.
My Bismarck is all stock besides tires (Stock size BFG KO2 C-rated) that I run at 38psi. I'm doing mostly city driving and occasionally freeway and county roads. I'm between 20mpg and 19.8mpg on my display. When I jump on a freeway and run 70-75mph (speed limit is 87mph) I see the number shown on the display drops down. Getting on county roads and driving 35-55mph the display goes up. In a city there is no drop in mpg unless I do a number of very short runs (cold engine).
Of course I play "ECO light game", which is not difficult as most cars here are stinking diesels with displacement less than 2 liters (my 95 4cyl Tacoma has better acceleration than most cars here). I have to admit, that these diesels get 50mpg even at highway speed, but really ... I don't care about mpg when in full year I did 2.5k miles total. But for sure none of these "high mpg diesels" can drive across my field :bluejump::flipoff:
11mpg? That's insane. I don't think I could accept cutting the driving range in half on these things since it's not that good to begin with.
I think stock tire size is the key if you want to maintain halfway decent fuel mileage. I run stock size Hankook Dynapro AT-M, which are also roughly the weight of stock tires and I didn't notice a change in mileage. In fact, it's getting better since I think my engine is broken in a bit more (at this point, I don't think they've changed fuel blends here yet). Recently went from Houston to Dallas, and averaged just over 21 mpg hand calculated for a stretch of 150 miles or so with speeds between 70-78 mph.
Calculated MPGs
Dang, man. What's your average mph on the highway? I do notice mpg is way better at 70mph than the 75-80 I like to drive at, but just curious what other habits you might be employing that are getting you such awesome mileage.
PRWhite
