Really specific tire question, any pics of 255/75 17 on a 17x8.5 -12 offset?
Crunching the numbers to see if this setup will work for me. On paper it should.
Curious how it’s going to look.
If you have pics of -12 or mid - offset on 255/75s please share.
What does “work for you” mean? No rubbing?
Given: stock wheels for SR5 and Off Road have a +15 offset and no rubbing with 265/70r17.
Given: TRD Pro wheels with a +4 offset move the outer edge of the same size tire outboard by 0.4 inches, and cutting/fender modification is required.
Using -12 offset wheels will push the tire 1.1 inches outboard of the SR5/Off Road wheels, and 0.62 inches outboard of the Pro wheels.
255’s are 0.4 inches narrower than the stock 265’s, so subtract 0.2 inches - 255’s on a -12 offset wheel will push the outer edge of the tire outboard 0.9 inches relative to an SR5 with stock wheels and tires, and 0.42 inches outboard relative to a PRO.
So “on paper” what it looks like to me is that if you are putting this wheel/ tire combo on a TRD Pro that has already had the fenders cut at the port it might work. If you are putting this combo on an SR5/OffRoad, you will need to do some trimming.
If anyone chimes in with contradictory empirical experience, take their advice and disregard mine, because it definitely falls within the realm of spitballing.
2001ATL
