Rear air bag suspension removal - LTD OWNERS
soundstudio315
My xreas is shock is leaking up front, so in planning on ditching that system I'm still left to deal with the zero lift options of having the rear air suspension.
Has anyone taken out the rear air bags and successfully installed coils as replacements?
Well your not left with zero lift options. You can always adjust the suspension to give you a couple inches of lift.
But if you'd like coils in the rear you can always buy a conversion kit. I don't think they have one for the 4runner specifically but the kit for the Lexus GX470 works. Someone over on toyota120 or ih8mud has done it.
Ill see if I can find some links.
EDIT: chaz beat me too it
Here's a link to Rebar's build, IMHO it's not the cleanest looking solution, but it works.
Also here's my build, but I went with leaf springs rather then coils, so again, probably not the cleanest looking option but it's works and is super fun offroad :)
Good luck with whatever u end up doin.
Thanks guys! I didn't want to reset the RAS to a new ride height, I guess I could and when it breaks go to full conversion at that point.
I'll take a look at the threads, RAS was a term i hadn't seen/used that's for the leads again.
Any feedback on the suncore kit vs the strutmasters? I too would only be using the spring perch/clips for the rear. I would upgrade to better shocks and springs.
I might have to wander over to the 120 board.
