rear and upper adjustable rear control arm length
ryanberls
I'm at wits end. Recently had a custom shop install the adjustable upper, lower rear control arms along with the panhard bar. They did not tighten the split nut causing alot of rattling. Does anyone know the exact length that these are suppose to be for a 2006 Toyota 4runner sr5. I wish I did it my self but was deployed overseas and in a tight pinch. Any help would be great full.
They probably set it to the stock length, but obviously didn't tighten the nuts up. You can tighten them up without having to the pull the arms, so try that first to see if it resolves the issue.
I'm hoping so, but with the history of this truck I'm going to say it's off. The worst luck ever. I'll cross my fingers and hoping the rattling will go away.
johnnya
