Bringing this thread back for some help/guidance, so thank you in advance to anyone that comes across this thread and responds. My 4th gen just hit 178k miles, and the larger tires and wheeling abuse over the last two years leading to this should have been expected..
I crawled under my car yesterday to grease the drive shafts, and noticed this only on the passenger side. There isn't a distinct smell or anything, but the leaking grease is everywhere. Under the rear bumper, all inside the wheel and tire, all inside the wheel well, all over the shock and spring, you get the point, it's all over the place. I drained and replaced the diff and transfer case fluid about 10k miles ago, no issues during that maintenance. So yesterday before work, I jacked the car up and took the wheel off yesterday. Cleaned everything that I could, and used and entire can of brake cleaner to help pinpoint the leak. Through research and reading along here, I suspect it is the rear axle seal leak.
From what I've gathered, replacing the seal isn't very difficult, but the bearing can be a PITA. It looks like I need #42311V for the right side seal, where is the best place to buy this seal? I checked Toyota Parts Online but the closest store is 65 miles away. Checked Ebay too, and couldn't find the exact seal match. Should I call the closest Toyota dealership and have them order it? I see some say go ahead and replace the bearing, others say to just do the seal. I feel confident enough to handle the seal alone, but not so much the bearing.
Sorry for any ignorance or stupidity in this post, anyone who stumbles across and can help offer suggestion would be really appreciated.
