Rear Axle Seals - Slight "bounce" when braking
erichbean
Hey guys, wanted to see if I could get an idea from y'all about what I am looking at for repair. Just got a call from the shop, took it in to have rear brakes checked. Got a call that the rear axle seal is leaking.
I took my 96 4Runner in because of a slight "bounce" or "skip" under breaking. It is not bad but needs to be addressed. Also, have a slight roar at around 65 mph that I think is likely related.
Any ideas of cost associated with repair? Also do y'all think the two symptoms are related?
It sounds like you may have a bad wheel bearing which will cause a roaring sound. a bad bearing can generate more heat than normal which can cause the axle seal to go bad. a leaking axle seal will obviously leave gear oil in the in the drum brake area leading to brake shoe saturation.
alexaturner
