REAR Brake Part numbers needed
tb-av
Member
Can someone help me out with some part numbers. I've looked all over the place and can't find the small parts I want.
2011 Limited
I have the pads and rotors they come in a bundle from coincelli but other stuff I want are the following.
Dust Boots
Dust Plugs
Caliper Slide Pin, aka Caliper Bush -- I found an after market set but would like Toyota
Anti-Squeal plate backing pads
Those 4 metal clips that wedge in to the calipers to hold the pads
Also it wouldn't be a bad to have the number of the 17mm short bolts that hold the caliper.
You can see all the parts I'm talking about in this vid ...
YouTube
Also any source for Lithium Soap Based Glycol Grease that's not $30 for a little tube?
Thanks!
TB
2011 Limited
Dust Boots
Dust Plugs
YouTube
Thanks!
TB
Here's a few part numbers......
Front Shim Kit: 04945-60090
Front Caliper Pins: 47735-60300
Front Caliper Pin hold (Spring): 47743-60280
Front Caliper Springs (fitting kit): 04947-35050
Front Anti-Rattle Spring: 47748-35010 (not needed if using fitting kit?)
Rear Shim Kit: 04946-60141 / 04946-60140
Rear Caliper Fitting kit: 04947-22050
Thanks guys. Took me awhile to get back.
All I need now are those rubber bushings and dust cover plugs.
charlesz
