hey guys need to replace driver side rear bracket, backed into a cement light post a few months back and bent it to hell:sobbing: also replacing driver side rear bumper end and main bumper component. do I need to remove tow package to go about doing this? my friend says yes but i got under the car myself today and that doesn't seem necessary.
Good stuff Brian:lol:You take out all the bolts until there aren't anymore to remove and then it comes off.
Sorry to hear of your slight mishap sir, but you are correct to say that it isn't necessary to remove the tow package in order to undo the bumper pieces..all 3 pieces.
thanks man! it was a sad day. i appreciate the advice. you ever switch out a bracket? if so how was it?
If you're referring to the bumper end pieces, AFAIK they're welded onto the bumper and can't be removed...but don't quote me on it, otherwise can't say I'd done it, can't help you there Chief!
From the factory they are just bolted on. (I have done it). You can remove the end pieces first, assuming you can get all the bolts to turn. You cannot remove the center piece first. I had to get the Sawzall to get mine off where the bolt heads snapped off, but I was able to save the brackets. I don't think changing those would be a big deal, as long as the bolts came out ok.
Easiest way is start at one wheel well (there is a bolt that goes through the fender wall) and work your way forward. Two key bolts are at the bottom corners of the hatch opening, under the plastic step cover. Then just do as Brian2Sun says...
