Rear hatch is fun, pop little cover off of pull strap on hatch and remove bolt (10mm), pop off the 4" x 4" cover and use it to pop the little panel tabs, so just pull. Peel off the moisture shield and it should be in there, if you need to remove the panel above your license plate you will need a 10mm deep socket and have to remove 6 nuts, 4 for the panel and 2 from back lock.
