Rear Clunk. 1+ cm of Lateral Play
salong53
Alright so my '04 V6 4X4 has developed a lot of lateral play in the rear suspension about 15000 miles after installing the Daystar spacer lift. From the driver's seat it feels like the entire rear axle shifts side-to-side 1+ cm when going over things like a diagonal speed bumps. It results in a very annoying clunk-clunk-clunk every time the weight shifts laterally in the rear.
When I climb underneath and have somebody shake the rear side-to-side I can hear the sound but I can't see any actual bushings with play in them. I think its on the driver's side but I can't be sure. My first suspect was the panhard rod bushings but I can't see any visual movement in them. I already replaced the sway bar bushings so I know it's not that. Anybody got suggestions?
Try holding to each bushing while the person shakes it sometimes you wont be able to see it if its slightly worn. But at least youll be able to feel whoch one is bad.
H.Sikina
