FS: 2000 Supercharged w/Locker Fernandina Beach, FL $12,500
atcpup
SOLD SOLD SOLD SOLD SOLD SOLD SOLD
I purchased this Runner in 2016 totally stock with 134,000 miles in 2016. Here we are 8 years and almost 75,000 miles later (208,701) and it's time to sale.
Suspension:
Front:~2.5” lift
Bilstein 6112 Driver set at 9 passenger at 8
SPC Upper Control Arms (Set at F for clearance)
Rear:~3.0" lift
-OME 890’s (initially had 2906s)
-Billstein 5100 Shocks
-Durobumps front and rear at 160,945
-CVJ CV axles part #9168-TR for lifted vehicles (their best!) at 161,200
Wheels/Tires:& Brakes
-TRD Pro Matte Gray - 17x7 5 in total (spare)
-199mm Tundra Brake Upgrade installed at 167,307
-Rear Disk Brake conversion (2000 Mustang Cobra R) see T4R.org thread
-Nitto Terra Grappler
-Load range “C"
-Wheeler’s front and rear brake lines
Engine and Performance
-Magnuson Supercharger (stock pulley) at 160,631 bought new and have manual
-URD 7th injector with 190lph fuel pump supplied with URD 7th (pump is noisy) bought new
-Deckplate Mod
-AiRaid Intake Elbow
-OEM filter
-Magnaflow Overland Cat-Back Part #19538 installed at 173,920
Undercarriage / Drive Train Upgrades:
-4.10 gear Ratio
-Off Road Solutions Electric Locker Harness for full locker control at 153,463
-Factory Retrofit E-locker: 4.10 gear Ratio with new OEM axle seals at 152,820
-RCI full aluminum skids
-RCI A-Arm skids 3/16” steel
-Sonaran Steel rear polyurethane body mounts
-Rear diff breather relocated higher up body(in gas door)
Interior Upgrades:
-Driver side Visor w/Homelink
-Katzkin full leather interior
-Scanguage installed where sunroof/sunglass holder is (reads Trans Temp
-Disabled Daytime Running Lights
-Innovate PSB-1 Air/Fuel and Boost gauge (with O2 sensor)
-Weather Tech front, rear and cargo mats
-Rago Rear Window Molle panels (cargo area)
Stereo
-Pioneer AVN2330NEX Double Din Touch Screen
Exterior Upgrades:
-Rola Roofrack with custom low profile mounts
-Satoshi Mod Grill with 4” Toyota Letters Emblem (have original grill)
-20% Tint all around
-Spiker Engineering Hood Struts
-Burtman Rear spoiler
**Exterior Lighting**
-Custom Retrofits (headlights) have originals
-Summit Racing 4 1/2” fog lights
-LED Corner Lights
SRQ Fabrications LED Front Turn signal under the headlight
Armor
-Custom Rear Lower Control Arm Mount Skids
-Stock Lower Control Arms with Whiteline bushings
-Shrockworks Rock Sliders at 158,940
- Smittybilt Winch 10000lbs
- Factor 55 Ultra Hook (Gray)
-RCI Aluminum Full skids
-Tru North Fabrications front plate bumper (SRQ Fab)
-CBI rear swing out rear bumper
Pics:
https://imgur.com/a/FPjH3UK
Vid of supercharger:
https://streamable.com/b2run1
Vid of elocker in action:
https://streamable.com/gvit06
New Toyota starter installed at 199,410
New AGM battery installed June 6, 2023 at 199,560
OEM Fuel filter replaced at 193,563
OEM Knock sensors and harness replaced at 193,440
Spark plugs Denso IK22s replaced at 181,022
Fumoto oil drain valve installed at 180,840
New OEM Eval canister installed at 170,976
New rear lift gate struts installed May 2020
SmittyBilt tire cover for spare tire on CBI bumper
Dynoed to check Air/Fuel 215(HP) and 270(ft-lbs)
New OEM radiator with hoses and T-stat at 161,129
New OEM Heater Air Valve at 161,433
Toyota OEM lower ball joints installed at 157,210 July 2018
OEM valve cover gaskets at 139,087
Timing Belt and Water Pump (OEM) at 134,885
Pros: see above
Cons: driver side rear door was replaced by previous owner, not sure what happened there. Rear hatch was replaced by me because I did not want to put holes in the original hatch for the Burtman Spoiler i had installed but the original hatch was damaged in my move from Atlanta to Florida so I ended up throwing it away.
You'll see a folder full of receipts in the pics documenting all the mods and maintenance. I'm selling because I bought a 2024 TRD Pro 4Runner and can't keep both, unfortunately. Let me know if you have any questions.
Thanks!
Craig
678-481-8443
murphyl2022
